Forum Archive Home -> ffmpegX general discussion -> Another install problem
| Another install problem | ||||
| AlecD posted 2008 Jun 03 09:01 | ||||
| Hi there,
I also am having binary install problems. I have all three binarys on the desktop, but get this error message when installing: ##sh: -c: line 1: unexpected EOF while looking for matching `'' sh: -c: line 2: syntax error: unexpected end of file I got all three files from the links in the ffmpegX install instructions. I do have Admin privileges. ffmpegX is in the shared Apps folder I have removed the space from my boot disk name. I have tried scourcing mpeg2enc various ways (from the zip file, and by copy/save as). I get the same error message each time. I don't think it matters, but I am confused about the correct suffix for this binary. Can it be .intel or .txt or blank? TIA, Alec | ||||
| Case posted 2008 Jun 03 12:05 | ||||
| John Duff posted 2008 Jun 03 12:49 | ||||
I got the exact same message, until I realized that I had a quote character in my ADMIN PASSWORD ! I changed my password to remove the quote, and everything ran fine. Obviously, this is a bug in ffmpegX. Hope that helps | ||||
| AlecD posted 2008 Jun 03 13:45 | ||||
| I removed the non alpha-numeric from the password and install seemed to go fine.
I then was asked 'Where is progress.app?' Finally discovered from this forum that ffmpegX.app should be selected. First .flv being generated as I type! Thanks, Alec |
Login/Register to our forum to be able to post here.
