Forum archive - 642 audio sync
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Players -> 642 audio sync
642 audio sync
catdaddio6 posted 2005 Jan 02 00:19
i have a movie that plays fine unless i ff or time jump then it is terribly outta sync,,it has cbr mp3 audio,,any suggestions,,other then the menu trick :wink:
Krispy Kritter posted 2005 Jan 11 11:42
That is a known issue with many players when time skipping or ff. No fix that I have seen as of yet.
mystery posted 2005 Jan 12 09:35
to get the sound back in sync, you just need to pause the player then hit play again. sometimes I have to do this 1-3 times but it always gets the sync ok again.
cosma posted 2005 Jan 13 05:34
covert everything audio and video stream in virtualdub and use a lower bitrate for audio
giannid posted 2005 Jan 13 15:44
I read on Jefferson Ryan's website that some Divx files desync when you apply the double-click gimmick to get the semi-transparent background. This affects divx and not xvid according to Jefferson. He says by double-clicking on the system menu that he believes this benefits xvid somehow (and perhaps to the detriment of divx).
I don't know if you were using the semi-transparent background when you had this problem and you were watching a divx file. If you were you can apply HuffyK's modified firmware update. This gives subtitle support without having to double click the system menu.
http://www.cfide.com.br/dvp/630_1109_lat2_v2.1.zip
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
